Build from 2017-01-05 : Paints for lights and bricks
Build from 2017-01-05 : Paints for lights and bricks Empty Build from 2017-01-05 : Paints for lights and bricks
Post by tsunamayo on Thu Jan 05, 2017 3:16 pm
Ok so for the new year I finally have paint for brick and light ! sunny
It was an heavy update as I changed a lot of stuff deep in the code and had to update the blueprint format several time.
You will loose brick based construction, but not too many people used that yet to it is fine.
I updated Le Saint Just, the Tsunami and the Alouette with the new bricks.
[CHANGELOG]
* Fix on Brick Build with offset.
* Paint working on Brick Entity.
* Stud are a bit easier to target.
* Fix bricks raycast for overlapping bricks.
* Optimization on lighting algorithm.
* Fix various Data Monitor.
* Fix stud logic for monitor screen wedge.
* Shader for block/brick geometry improved : better filtering and faster borders.
* Screen Space Ambiant Occlusion desactivated for now.
* Block Light added.
* Brick light shape and build logic modified.
* Item Icon super sampling.
* Weapons color can be painted.
* Tabs are re-organized
* Some bricks icon preview are re-oriented
[Known issues]
* now there is some seams issue on some texture, it is linked to the new shader, I will have to update these one by one.
* Block sounds are to be re-implemented.
Check out the instruction on how to install the latest build : http://skywanderers.forumjap.com/t11-to-read-first-install-the-game-save
Dont forget to use the latest saves in the dropbox also.
Now I will do some post in various sections on what I would like to test in the coming day if some of you want to help me out on that.
Next step is to continue the codex re-organization by bundling bricks in more logical shapes, and do the bulk-shape merge at the level of the item.
I will add also some advanced command for advanced builders  Cool
Thanks !
video :
Build from 2017-01-05 : Paints for lights and bricks Empty Re: Build from 2017-01-05 : Paints for lights and bricks
Post by DarganLor on Fri Jan 06, 2017 8:26 am
Cool! Looking forward to test this out!
DarganLor
Post by Remitorm Darkwind on Sat Jan 07, 2017 1:37 am
finally mode lighting Razz
Remitorm Darkwind
Remitorm Darkwind
Post by tsunamayo on Sun Jan 08, 2017 2:52 pm
Some behind the scene of during the update, a lot of things were broken tongue  :
Build from 2017-01-05 : Paints for lights and bricks Zplg0P5h
Build from 2017-01-05 : Paints for lights and bricks FW7fcOEh
Post by DarganLor on Sun Jan 08, 2017 6:38 pm
Ouch... Seems you got it sorted though! Smile
DarganLor
Post by tsunamayo on Sun Jan 08, 2017 6:48 pm
yeah no worries that was 100% expected, I updated the way block rotation are sorted in the blueprint format so I had to do mapping to the new format (1st pic was without the mapping), and I changed the way color are deal with because of the paint system, so I had to retouch all the textures (that was for the tedious part lol)
Post by Remitorm Darkwind on Sun Jan 08, 2017 7:53 pm
well now I know what the quantum realm looks like...
Remitorm Darkwind
Remitorm Darkwind
