Skywanderers
[Fixed] Loading save files after returning to the title screen problem
[Fixed] Loading save files after returning to the title screen problem Empty [Fixed] Loading save files after returning to the title screen problem
Post by Guest Sun Jan 08, 2017 8:29 pm
Sometimes after you load a save file and then exit to the title screen you can't seem to be able to load any save file again and when you click on the save file you are presented with a "menu button click"(like when you go to options) sound effect. Restart fixes problem.
Guest
Guest
[Fixed] Loading save files after returning to the title screen problem Empty Re: [Fixed] Loading save files after returning to the title screen problem
Post by tsunamayo Mon Jan 09, 2017 11:52 am
Ok I will see if I can reproduce, believe it or not this is actually not trivial to make it work with unity Razz
https://skywanderers.forumjap.com
Post by Guest Mon Jan 09, 2017 12:03 pm
Oh I believe Smile Gamedev is anything but trivial.
Guest
Guest
Post by tsunamayo Mon Jan 09, 2017 12:27 pm
I fixed a bug that I was having but it was only an error message I did not had any real issue. I try a few time more to see if I get a similar issue.
