[Low priority] [Visual] Menu stars background glitch when changing resolution
[Low priority] [Visual] Menu stars background glitch when changing resolution Empty [Low priority] [Visual] Menu stars background glitch when changing resolution
Post by johnreverse on Tue Jan 10, 2017 3:05 pm
To replicate:
1. Change your resolution to whatever resolution smaller than your current one.
2. Change your resolution to your original resolution.
The moving stars background will either behave normally or glitch out in 2 ways(which I currently know of):
1. Stars background disappears and you are left with a clean purple background.
2. Stars background gets "windowed"  and you can see clean purple background "margin" around its edges.
Noticed on build 2017-01-10.
Present in the previous build(2017-01-08) as well.
Pictures:
[Low priority] [Visual] Menu stars background glitch when changing resolution 0d3b0129c6
[Low priority] [Visual] Menu stars background glitch when changing resolution 0c476377f5
johnreverse
[Low priority] [Visual] Menu stars background glitch when changing resolution Empty Re: [Low priority] [Visual] Menu stars background glitch when changing resolution
Post by tsunamayo on Mon Jan 16, 2017 6:05 pm
issue : link
http://skywanderers.forumjap.com
