[Fixed] Weapon table hologram stays up after removing the block
Once you remove the table while designing the weapon you get left with this:
It can't be destroyed even if you remove the block beneath it(as you can see in the ss).
Doing that doesn't work:
That doesn't work as well:
Guest- Guest
Re: [Fixed] Weapon table hologram stays up after removing the block
Will be fixed in the next update.
Similar topics
» Weapon table
» [FIXED][Medium Priority][Building] Removing Logical Componets, does not remove the component.
» When hitting F2 to hide HUD, also disable the wireframe block highlighting that shows the boundary of whichever block you're looking at.
» Rail child block invinsibility
» Video How-to #02 : Rotating Block
